Saltar al contenido principal
HP Pavilion x360 15t-br000 Speakers Replacement
Qué necesitas
  1. HP Pavilion x360 15t-br000 Speakers Replacement, Keyboard Panel: paso 1, imagen 1 de 3 HP Pavilion x360 15t-br000 Speakers Replacement, Keyboard Panel: paso 1, imagen 2 de 3 HP Pavilion x360 15t-br000 Speakers Replacement, Keyboard Panel: paso 1, imagen 3 de 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Speakers Replacement: paso 2, imagen 1 de 3 HP Pavilion x360 15t-br000 Speakers Replacement: paso 2, imagen 2 de 3 HP Pavilion x360 15t-br000 Speakers Replacement: paso 2, imagen 3 de 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Speakers Replacement, Battery: paso 3, imagen 1 de 1
    • Disconnect the battery cable from the device.
  4. HP Pavilion x360 15t-br000 Speakers Replacement: paso 4, imagen 1 de 2 HP Pavilion x360 15t-br000 Speakers Replacement: paso 4, imagen 2 de 2
    • Remove the seven Phillips #0 4.5 mm screws.
    • Remove the battery from the device.
  5. HP Pavilion x360 15t-br000 Speakers Replacement, Speakers: paso 5, imagen 1 de 3 HP Pavilion x360 15t-br000 Speakers Replacement, Speakers: paso 5, imagen 2 de 3 HP Pavilion x360 15t-br000 Speakers Replacement, Speakers: paso 5, imagen 3 de 3
    • Disconnect the white speaker cable connection from the motherboard.
    • Unscrew the four 3 mm screws mounting the speakers to the laptop using a Phillips #0 screwdriver.
    • Remove the speakers from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 116
