Introducción
Use this guide to replace the fan in your HP Pavilion x360 15t-br000 laptop.
One side of the fan is at the bottom of the mainboard. So the mainboard should be replaced first. The laptop may be overheated if the fan is broken.
Remember to shut down the laptop when doing the replacement.
Qué necesitas
Remove the covers to access the screws attached to the back cover of the device.
Remove six 3mm screws using the Phillips #0 screwdriver.
Remove all three 3.5 mm screws using the Phillips #0 screwdriver.
Disconnect the cables above the fan.
Disconnect the wire next to the fan.
Una persona más ha completado esta guía.
