Saltar al contenido principal
HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement
Qué necesitas
  1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: paso 1, imagen 1 de 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: paso 1, imagen 2 de 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: paso 1, imagen 3 de 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: paso 2, imagen 1 de 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: paso 2, imagen 2 de 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: paso 2, imagen 3 de 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: paso 3, imagen 1 de 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: paso 3, imagen 2 de 3 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: paso 3, imagen 3 de 3
    • Remove all three 3.5 mm screws using the Phillips #0 screwdriver.
    • Disconnect the cables above the fan.
    • Disconnect the wire next to the fan.
  4. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: paso 4, imagen 1 de 1
    • Remove nine 4mm screws using the Phillips #0 screwdriver.
  5. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: paso 5, imagen 1 de 1
    • Flip over the motherboard.
  6. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: paso 6, imagen 1 de 2 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: paso 6, imagen 2 de 2
    • Remove four 3.5mm screws using the Phillips #0 screwdriver.
    • Remove the fan and heatsink assembly from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 517
