Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion x360 14m-cd0005dx Speaker Replacement
Qué necesitas
  1. HP Pavilion x360 14m-cd0005dx Speaker Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 2, imagen 1 de 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 3, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 3, imagen 2 de 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 4, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 4, imagen 2 de 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 5, imagen 1 de 3 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 5, imagen 2 de 3 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 5, imagen 3 de 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Speaker Replacement, Battery: paso 6, imagen 1 de 3 HP Pavilion x360 14m-cd0005dx Speaker Replacement, Battery: paso 6, imagen 2 de 3 HP Pavilion x360 14m-cd0005dx Speaker Replacement, Battery: paso 6, imagen 3 de 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 7, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 7, imagen 2 de 2
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Speaker Replacement, Heat Sink and Fan: paso 8, imagen 1 de 1
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 9, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 10, imagen 1 de 3 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 10, imagen 2 de 3 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 10, imagen 3 de 3
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 11, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 11, imagen 2 de 2
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
  12. HP Pavilion x360 14m-cd0005dx Speaker Replacement, Keyboard: paso 12, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Speaker Replacement, Keyboard: paso 12, imagen 2 de 2
    • Remove all screws securing the hinges to the device:
    • Four Phillips #0 4.5mm screws
    • After removing the hinge screws, it can be harder to turn the laptop. Be sure to not force it, but pressing on the hinge itself to make it move may help when manipulating the screen.
  13. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 13, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 13, imagen 2 de 2
    • Grab the ribbon wires by the edge of the socket and pull to remove them from the motherboard.
  14. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 14, imagen 1 de 1
    • Rotate the screen backwards until only the keyboard is visible.
  15. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 15, imagen 1 de 1
    • Run an Opening Tool along the edge of the device.
    • Pull the plastic keyboard up and away from the base of the laptop.
    • There is adhesive attaching the keyboard to the base of the laptop. Continue to pull the keyboard up and out; ignore the resistance.
    • Pull up on the metal casing of the keyboard below the keyboard's surface once a hand can adequately fit under the gap.
  16. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 16, imagen 1 de 1
    • Gently raise the keyboard up and keep pulling to remove it from the base housing.
    • Do not pull just the top casing off. It is brittle and it may break. Ensure that the opening tool is beneath the keyboard in its entirety.
  17. HP Pavilion x360 14m-cd0005dx Speaker Replacement, Speaker: paso 17, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Speaker Replacement, Speaker: paso 17, imagen 2 de 2
    • Flip the device over so the hinge is at the top and the motherboard, and other components are visible.
  18. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 18, imagen 1 de 3 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 18, imagen 2 de 3 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 18, imagen 3 de 3
    • Use the Reverse Tweezers to remove the ribbon wires connecting the speaker to the motherboard.
  19. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 19, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 19, imagen 2 de 2
    • Grab the ribbon wires by the edge of the socket and pull to remove the wire connecting the speaker to the motherboard.
    • Grand and pull to remove the wire connecting the speaker to the wireless card housing.
  20. HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 20, imagen 1 de 3 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 20, imagen 2 de 3 HP Pavilion x360 14m-cd0005dx Speaker Replacement: paso 20, imagen 3 de 3
    • Grab the speaker and pull out to remove the speakers from the hinge housing.
    • The disconnected wires may be slightly tangled within the housing. Grab and pull gently to remove from the enclosure.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 30
Todo El Tiempo: 429
