Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion x360 14m-cd0005dx Battery Replacement
Qué necesitas
  1. HP Pavilion x360 14m-cd0005dx Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Battery Replacement: paso 2, imagen 1 de 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Battery Replacement: paso 3, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: paso 3, imagen 2 de 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Battery Replacement: paso 4, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: paso 4, imagen 2 de 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Battery Replacement: paso 5, imagen 1 de 3 HP Pavilion x360 14m-cd0005dx Battery Replacement: paso 5, imagen 2 de 3 HP Pavilion x360 14m-cd0005dx Battery Replacement: paso 5, imagen 3 de 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: paso 6, imagen 1 de 3 HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: paso 6, imagen 2 de 3 HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: paso 6, imagen 3 de 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Battery Replacement: paso 7, imagen 1 de 2 HP Pavilion x360 14m-cd0005dx Battery Replacement: paso 7, imagen 2 de 2
    • Carefully lift from the base and remove the battery.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 33
Todo El Tiempo: 1,722
