Saltar al contenido principal
HP Pavilion x360 14m-cd0003dx Touchpad Replacement
Qué necesitas
  1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: paso 2, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: paso 2, imagen 2 de 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: paso 3, imagen 1 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: paso 3, imagen 2 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: paso 3, imagen 3 de 3
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
  4. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: paso 4, imagen 1 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: paso 4, imagen 2 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: paso 4, imagen 3 de 3
    • Lift the black tab on the ZIF connector, and gently pull the track pad ribbon cable free.
  5. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: paso 5, imagen 1 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: paso 5, imagen 2 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: paso 5, imagen 3 de 3
    • Use a Phillips Head Screwdriver to remove the bottom 3 screws (5 mm).
    • Remove the metal plate that secures the touch pad.
  6. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: paso 6, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: paso 6, imagen 2 de 2
    • Use a Phillips Head Screwdriver to unscrew top 3 screws (5 mm).
    • Remove touch pad.
Conclusión
Elijah Jope
Miembro Desde 03/22/22
379 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Miembro de UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
Miembros de 6
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 425
