Saltar al contenido principal
HP Pavilion x360 14m-cd0003dx Screen Replacement
Qué necesitas
  1. HP Pavilion x360 14m-cd0003dx Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to carefully separate the screen from the plastic frame.
    • Work along the top first, and then down the left and right sides.
  3. HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 3, imagen 1 de 1
    • The screen can then be separated from the frame and laid flat on top of the keyboard.
    • Do not pull and try to remove yet, as the screen is still connected by several cables.
  4. HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 4, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 4, imagen 2 de 2
    • The next few steps involve disconnecting the screen from the laptop in several places.
    • The first place is connected to the left side of the thin blue board at the top.
    • Peel back the clear adhesive and remove the pin header from the port on the blue board.
  5. HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 5, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 5, imagen 2 de 2
    • The next place is underneath the gray adhesive. Peel back this adhesive to expose the connection underneath.
    • Disconnect the gold pin header from its port.
  6. HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 6, imagen 1 de 1
    • Repeat Step 4 for the connection on the right side.
    • Peel the clear adhesive and remove connection.
  7. HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 7, imagen 1 de 3 HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 7, imagen 2 de 3 HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 7, imagen 3 de 3
    • Peel the thin gray adhesive strips.
    • Pull out the thin black cable underneath these strips. It is the same black cable that was disconnected in the previous steps.
  8. HP Pavilion x360 14m-cd0003dx Screen Replacement: paso 8, imagen 1 de 1
    • After the cable has been disconnected, the screen can be removed.
Conclusión
Una persona más ha completado esta guía.
Elijah Jope
Miembro Desde 03/22/22
379 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Miembro de UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
Miembros de 6
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 11
Todo El Tiempo: 893
