Saltar al contenido principal
HP Pavilion x360 14m-cd0003dx SSD Replacement
Qué necesitas
  1. HP Pavilion x360 14m-cd0003dx SSD Replacement, SSD: paso 1, imagen 1 de 1
    • Make sure computer is turned off
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx SSD Replacement: paso 2, imagen 1 de 3 HP Pavilion x360 14m-cd0003dx SSD Replacement: paso 2, imagen 2 de 3 HP Pavilion x360 14m-cd0003dx SSD Replacement: paso 2, imagen 3 de 3
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx SSD Replacement: paso 3, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx SSD Replacement: paso 3, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the 5 mm screw that secures the SSD.
  4. HP Pavilion x360 14m-cd0003dx SSD Replacement: paso 4, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx SSD Replacement: paso 4, imagen 2 de 2
    • Peel back the black covering.
    • Pull out SSD.
Conclusión
Jack Benfeito
Miembro Desde 03/22/22
180 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Miembro de UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
Miembros de 6
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 19
Todo El Tiempo: 923
