Saltar al contenido principal
HP Pavilion x360 14m-cd0003dx Hinges Replacement
Qué necesitas
  1. HP Pavilion x360 14m-cd0003dx Hinges Replacement, Screen: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to carefully separate the screen from the plastic frame.
    • Work along the top first, and then down the left and right sides.
  3. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 3, imagen 1 de 1
    • The screen can then be separated from the frame and laid flat on top of the keyboard.
    • Do not pull and try to remove yet, as the screen is still connected by several cables.
  4. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 4, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 4, imagen 2 de 2
    • The next few steps involve disconnecting the screen from the laptop in several places.
    • The first place is connected to the left side of the thin blue board at the top.
    • Peel back the clear adhesive and remove the pin header from the port on the blue board.
  5. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 5, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 5, imagen 2 de 2
    • The next place is underneath the gray adhesive. Peel back this adhesive to expose the connection underneath.
    • Disconnect the gold pin header from its port.
  6. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 6, imagen 1 de 1
    • Repeat Step 4 for the connection on the right side.
    • Peel the clear adhesive and remove connection.
  7. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 7, imagen 1 de 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 7, imagen 2 de 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 7, imagen 3 de 3
    • Peel the thin gray adhesive strips.
    • Pull out the thin black cable underneath these strips. It is the same black cable that was disconnected in the previous steps.
  8. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 8, imagen 1 de 1
    • After the cable has been disconnected, the screen can be removed.
  9. HP Pavilion x360 14m-cd0003dx Hinges Replacement, Hinges: paso 9, imagen 1 de 1
    • Remove the three Phillip Head screws (5 mm)that hold in the bracket on each side.
  10. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 10, imagen 1 de 1
    • Slide the frame down past the brackets on each side.
  11. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 11, imagen 1 de 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 11, imagen 2 de 3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 11, imagen 3 de 3
    • Lay the laptop flat on your working surface.
    • Flip it over to get access to the back panel.
    • Remove the back panel screws and take off the back cover.
  12. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 12, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 12, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the 5 mm screws from the hinges on each side inside the laptop.
  13. HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 13, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: paso 13, imagen 2 de 2
    • Remove the hinges from both sides of the laptop.
Conclusión
Una persona más ha completado esta guía.
Elijah Jope
Miembro Desde 03/22/22
379 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Miembro de UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
Miembros de 6
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 21
Ultimos 30 días: 62
Todo El Tiempo: 2,648
