Saltar al contenido principal
HP Pavilion x360 14m-cd0003dx Fan Replacement
Qué necesitas
  1. HP Pavilion x360 14m-cd0003dx Fan Replacement, Heat Sink and Fan: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Fan Replacement: paso 2, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: paso 2, imagen 2 de 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Fan Replacement: paso 3, imagen 1 de 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: paso 3, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws that secure the fan and heatsink.
  4. HP Pavilion x360 14m-cd0003dx Fan Replacement: paso 4, imagen 1 de 1
    • Peel back the retention tape that secures the heat sink assembly.
  5. HP Pavilion x360 14m-cd0003dx Fan Replacement: paso 5, imagen 1 de 1
    • Disconnect the fan cable from the connector on the system board.
  6. HP Pavilion x360 14m-cd0003dx Fan Replacement: paso 6, imagen 1 de 1
    • Remove the heat sink assembly from the device.
Conclusión
2 personas más completaron esta guía.
Riley McMorrow
Miembro Desde 03/22/22
264 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 465
