Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
HP Pavilion x360 14m-ba011dx Motherboard Replacement
Vistas: 2.3 k
Ver estadísticas:
Últimas 24 horas:
3
Últimos 7 días:
17
Últimos 30 días:
68
Todo El Tiempo:
2,298
Comentarios: 0
Nadie ha escrito comentarios en esta guía. ¿Quieres escribir el primero?
Ir a los comentarios de la guía
Completado: 1
1 persona ha marcado esta guía como "completada". ¿Serás tú la próxima persona en hacerlo?
Favoritos: 0
Nadie ha marcado como "Favorita" ni se ha suscrito a esta guía. ¿Quieres hacerlo tú?
Tiempo Requerido: 9 - 15 minutos
Dificultad: Moderado
Introducción
Ir al paso 1 ↓
Before using this guide, make sure to review the troubleshooting page for the HP Pavilion x360 14m-ba011dx. The motherboard may not actually need to be replaced depending on the problem, which is why it is good to trouble shoot first.
With this guide, the user will be able to remove and replace the motherboard of the HP Pavilion x360 14m-ba011dx laptop. The model number for this device is 1KT47UA. The motherboard is one of the most essential parts of your computer because it controls many different components of the laptop such as memory and the connectors for inputs and outputs. The motherboard may need to be replaced if your computer is having any hardware issues.
Qué necesitas
Herramientas
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. HP Pavilion x360 14m-ba011dx Motherboard Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion x360 14m-ba011dx Motherboard Replacement, Battery: paso 1, imagen 2 de 2
      • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
      • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
      • Two 7.5 mm screws.
      • Three 5 mm screws.
      • One 6.5 mm screw.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Pavilion x360 14m-ba011dx Motherboard Replacement: paso 2, imagen 1 de 1
      • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
      • Do this with the screen open so that you do not damage the screen.
      • Do not remove keyboard all the way.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Pavilion x360 14m-ba011dx Motherboard Replacement: paso 3, imagen 1 de 2 HP Pavilion x360 14m-ba011dx Motherboard Replacement: paso 3, imagen 2 de 2
      • Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
      • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
      • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
      Pregunta a FixBot
      Agregar Comentario
    4. HP Pavilion x360 14m-ba011dx Motherboard Replacement: paso 4, imagen 1 de 2 HP Pavilion x360 14m-ba011dx Motherboard Replacement: paso 4, imagen 2 de 2
      • Remove the purple cable attaching the battery to the motherboard by flipping the black flap and pulling the cable out.
      • Remove seven 4 mm screws using a Phillips #00 Screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    5. HP Pavilion x360 14m-ba011dx Motherboard Replacement: paso 5, imagen 1 de 1
      • Remove the battery by gently pushing battery up, then pulling.
      Pregunta a FixBot
      Agregar Comentario
    1. HP Pavilion x360 14m-ba011dx Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 HP Pavilion x360 14m-ba011dx Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
      • Unclip the 5 cables connecting the motherboard to the computer.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Pavilion x360 14m-ba011dx Motherboard Replacement: paso 7, imagen 1 de 1
      • Remove ten 4 mm screws using a Phillips #00 screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Pavilion x360 14m-ba011dx Motherboard Replacement: paso 8, imagen 1 de 1
      • Gently remove the motherboard.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Autor
con
Katie Pruis
Miembro Desde 01/16/20
820 Reputación
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 68
Todo El Tiempo: 2,298
