Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion x360 14m-ba011dx Battery Replacement
Qué necesitas
    1. HP Pavilion x360 14m-ba011dx Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion x360 14m-ba011dx Battery Replacement, Battery: paso 1, imagen 2 de 2
      • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
      • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
      • Two 7.5 mm screws.
      • Three 5 mm screws.
      • One 6.5 mm screw.
      Pregunta a FixBot
      Agregar Comentario
    2. HP Pavilion x360 14m-ba011dx Battery Replacement: paso 2, imagen 1 de 1
      • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
      • Do this with the screen open so that you do not damage the screen.
      • Do not remove keyboard all the way.
      Pregunta a FixBot
      Agregar Comentario
    3. HP Pavilion x360 14m-ba011dx Battery Replacement: paso 3, imagen 1 de 2 HP Pavilion x360 14m-ba011dx Battery Replacement: paso 3, imagen 2 de 2
      • Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
      • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
      • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
      Pregunta a FixBot
      Agregar Comentario
    4. HP Pavilion x360 14m-ba011dx Battery Replacement: paso 4, imagen 1 de 2 HP Pavilion x360 14m-ba011dx Battery Replacement: paso 4, imagen 2 de 2
      • Remove the purple cable attaching the battery to the motherboard by flipping the black flap and pulling the cable out.
      • Remove seven 4 mm screws using a Phillips #00 Screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    5. HP Pavilion x360 14m-ba011dx Battery Replacement: paso 5, imagen 1 de 1
      • Remove the battery by gently pushing battery up, then pulling.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
3 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 24
Ultimos 30 días: 104
Todo El Tiempo: 5,562
