Saltar al contenido principal
HP Pavilion x360 11-p110nr Speakers Replacement
Qué necesitas
  1. HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: paso 1, imagen 1 de 3 HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: paso 1, imagen 2 de 3 HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: paso 1, imagen 3 de 3
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Carefully take the bottom cover off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Speakers Replacement: paso 2, imagen 1 de 3 HP Pavilion x360 11-p110nr Speakers Replacement: paso 2, imagen 2 de 3 HP Pavilion x360 11-p110nr Speakers Replacement: paso 2, imagen 3 de 3
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Once located, lift the small black flap and carefully pull the cable out.
  3. HP Pavilion x360 11-p110nr Speakers Replacement: paso 3, imagen 1 de 3 HP Pavilion x360 11-p110nr Speakers Replacement: paso 3, imagen 2 de 3 HP Pavilion x360 11-p110nr Speakers Replacement: paso 3, imagen 3 de 3
    • Remove the large cable connecting the battery to the main board
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the speakers could also lead to risk of electrocution.
  4. HP Pavilion x360 11-p110nr Speakers Replacement: paso 4, imagen 1 de 3 HP Pavilion x360 11-p110nr Speakers Replacement: paso 4, imagen 2 de 3 HP Pavilion x360 11-p110nr Speakers Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Locate the cable for the speakers and unplug, as shown.
    • If needed, use the tweezers to gently remove the cable from its connector.
  5. HP Pavilion x360 11-p110nr Speakers Replacement: paso 5, imagen 1 de 3 HP Pavilion x360 11-p110nr Speakers Replacement: paso 5, imagen 2 de 3 HP Pavilion x360 11-p110nr Speakers Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the four 5.8 mm screws from the speakers.
    • The speakers are now not secured to the laptop.
  6. HP Pavilion x360 11-p110nr Speakers Replacement: paso 6, imagen 1 de 3 HP Pavilion x360 11-p110nr Speakers Replacement: paso 6, imagen 2 de 3 HP Pavilion x360 11-p110nr Speakers Replacement: paso 6, imagen 3 de 3
    • Lift each speaker out of the laptop.
    • Carefully remove each speaker.
    • The speakers are connected to each other by a wire.
Conclusión
Aeorrell
Miembro Desde 03/27/23
433 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-2, Harley Spring 2023 Miembro de IUPUI, Team 1-2, Harley Spring 2023
IUPUI-HARLEY-S23S1G2
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 68
