Saltar al contenido principal
HP Pavilion x2 10-n113dx Mainboard Replacement
Qué necesitas
  1. HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: paso 1, imagen 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: paso 1, imagen 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: paso 1, imagen 3 de 3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 2, imagen 1 de 2 HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 2, imagen 2 de 2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 3, imagen 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 3, imagen 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 3, imagen 3 de 3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 4, imagen 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 4, imagen 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 4, imagen 3 de 3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 5, imagen 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 5, imagen 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 5, imagen 3 de 3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
  6. HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: paso 6, imagen 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: paso 6, imagen 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: paso 6, imagen 3 de 3
    • To unscrew the mainboard use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws
  7. HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 7, imagen 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 7, imagen 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: paso 7, imagen 3 de 3
    • Remove mainboard.
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team S13-G4, Boczar Fall 2017 Miembro de USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 Miembros
5 Guías creadas
4 comentarios
Is this about the WiFi card? Because I cant see the SSD in any of your pictures.
Julian Lemmerich - Contestar
So, where is the SSD? You’ve taken apart the whole logic board, but not evidence of any SSD module from your photos….
Matteo Repossi - Contestar
It is not SSD drive, it is a motherboard
Da K - Contestar
has anyone figured out where is the SSD (eMMC) by the way ?
Karantez Jegou - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 30
Todo El Tiempo: 7,428
