Saltar al contenido principal
HP Pavilion tx2500 Fan Replacement
Qué necesitas
  1. HP Pavilion tx2500 Fan  Replacement, Screen Rotator: paso 1, imagen 1 de 1
    • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
  2. HP Pavilion tx2500 Fan  Replacement: paso 2, imagen 1 de 2 HP Pavilion tx2500 Fan  Replacement: paso 2, imagen 2 de 2
    • Squeeze the latches on the battery until you hear a click. Slide out the battery.
  3. HP Pavilion tx2500 Fan  Replacement: paso 3, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
    • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
  4. HP Pavilion tx2500 Fan  Replacement: paso 4, imagen 1 de 1
    • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
  5. HP Pavilion tx2500 Fan  Replacement: paso 5, imagen 1 de 1
    • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
  6. HP Pavilion tx2500 Fan  Replacement: paso 6, imagen 1 de 1
    • Use the plastic opening tool to disconnect the wires in the upper corners.
  7. HP Pavilion tx2500 Fan  Replacement: paso 7, imagen 1 de 1
    • Flip the laptop front side up and then use your fingers to lift up the keyboard.
  8. HP Pavilion tx2500 Fan  Replacement: paso 8, imagen 1 de 1
    • Lift up the black latch that connects the film strip to the base of the computer.
    • Use the plastic opening tool to disconnect the film strip from the base of the computer.
  9. HP Pavilion tx2500 Fan  Replacement: paso 9, imagen 1 de 2 HP Pavilion tx2500 Fan  Replacement: paso 9, imagen 2 de 2
    • Rotate the screen 90 degrees and remove the base under the screen.
  10. HP Pavilion tx2500 Fan  Replacement: paso 10, imagen 1 de 1
    • Rotate the screen back towards you.
    • Lift up the convertible hinge to unclip it from the base of the computer.
  11. HP Pavilion tx2500 Fan  Replacement: paso 11, imagen 1 de 2 HP Pavilion tx2500 Fan  Replacement: paso 11, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
  12. HP Pavilion tx2500 Fan  Replacement: paso 12, imagen 1 de 1
    • Gently lift up and remove the screen.
  13. HP Pavilion tx2500 Fan  Replacement, Fan: paso 13, imagen 1 de 3 HP Pavilion tx2500 Fan  Replacement, Fan: paso 13, imagen 2 de 3 HP Pavilion tx2500 Fan  Replacement, Fan: paso 13, imagen 3 de 3
    • Disconnect the wire from the system board using the plastic opening tool.
    • Disconnect the wire from the optical drive using the plastic opening tool.
    • Gently lift the top cover from the tablet.
  14. HP Pavilion tx2500 Fan  Replacement: paso 14, imagen 1 de 2 HP Pavilion tx2500 Fan  Replacement: paso 14, imagen 2 de 2
    • Using the plastic opening tool, disconnect the plastic blue film from the tablet.
    • Disconnect the wire using the plastic opening tool.
  15. HP Pavilion tx2500 Fan  Replacement: paso 15, imagen 1 de 2 HP Pavilion tx2500 Fan  Replacement: paso 15, imagen 2 de 2
    • Lift the system board from the tablet.
    • Turn the system board over and lay it flat on a soft surface.
  16. HP Pavilion tx2500 Fan  Replacement: paso 16, imagen 1 de 2 HP Pavilion tx2500 Fan  Replacement: paso 16, imagen 2 de 2
    • Using a Phillips #00, remove the 4.5 mm screws that connect the fan to the board.
    • Using a plastic opening tool, disconnect the wire that attached the fan to the board.
  17. HP Pavilion tx2500 Fan  Replacement: paso 17, imagen 1 de 1
    • Gently lift the fan away from the board.
Conclusión
Una persona más ha completado esta guía.
Ricardo
Miembro Desde 10/13/15
164 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 910
