Saltar al contenido principal
HP Pavilion g7-1368dx Keyboard Replacement
Qué necesitas
  1. HP Pavilion g7-1368dx Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx Keyboard Replacement: paso 2, imagen 1 de 1
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
    • Slide the service panel down and pull it up to remove.
  4. HP Pavilion g7-1368dx Keyboard Replacement: paso 4, imagen 1 de 1
    • Remove the one 7 mm Phillips #1 screw securing the keyboard to the device.
  5. HP Pavilion g7-1368dx Keyboard Replacement: paso 5, imagen 1 de 1
    • Flip over the device and open the screen.
  6. HP Pavilion g7-1368dx Keyboard Replacement: paso 6, imagen 1 de 2 HP Pavilion g7-1368dx Keyboard Replacement: paso 6, imagen 2 de 2
    • Flip the keyboard over and locate the black ribbon cable that attaches the keyboard to the device.
    • Using a plastic opening tool, flip up the white tab on the zero insertion force connector.
    • Disconnect the ribbon cable by sliding it out of the ZIF connector.
    • Remove the keyboard.
Conclusión
Kianna Young
Miembro Desde 01/16/19
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 271
