Saltar al contenido principal
HP Pavilion g7-1368dx Hard Drive Replacement
Qué necesitas
  1. HP Pavilion g7-1368dx  Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx  Hard Drive Replacement: paso 2, imagen 1 de 1
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx  Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
  4. HP Pavilion g7-1368dx  Hard Drive Replacement: paso 4, imagen 1 de 1
    • Slide the service panel down and pull it up to remove.
  5. HP Pavilion g7-1368dx  Hard Drive Replacement: paso 5, imagen 1 de 2 HP Pavilion g7-1368dx  Hard Drive Replacement: paso 5, imagen 2 de 2
    • Locate the hard drive.
    • It is missing from the device pictured here.
    • Disconnect the cable connector by pulling it away from the hard drive.
    • Remove the hard drive from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 312
