Saltar al contenido principal
HP Pavilion g7-1365dx RTC Battery Replacement
Qué necesitas
  1. HP Pavilion g7-1365dx RTC Battery Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx RTC Battery Replacement: paso 2, imagen 1 de 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx RTC Battery Replacement, Service Door: paso 3, imagen 1 de 2 HP Pavilion g7-1365dx RTC Battery Replacement, Service Door: paso 3, imagen 2 de 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx RTC Battery Replacement, RTC Battery: paso 4, imagen 1 de 2 HP Pavilion g7-1365dx RTC Battery Replacement, RTC Battery: paso 4, imagen 2 de 2
    • Disconnect the RTC battery power cable from the system board.
    • Remove the RTC battery from the system board. (The RTC battery is attached to the system board with double-sided tape.)
    • Slide the RTC battery out from under the surface of the base enclosure.
Conclusión
Derrick Manu
Miembro Desde 03/18/19
245 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 27
Todo El Tiempo: 1,594
