Saltar al contenido principal
HP Pavilion g7-1365dx Optical Drive Replacement
Qué necesitas
  1. HP Pavilion g7-1365dx Optical Drive Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Optical Drive Replacement: paso 2, imagen 1 de 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Optical Drive Replacement, Service Door: paso 3, imagen 1 de 2 HP Pavilion g7-1365dx Optical Drive Replacement, Service Door: paso 3, imagen 2 de 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: paso 4, imagen 1 de 3 HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: paso 4, imagen 2 de 3 HP Pavilion g7-1365dx Optical Drive Replacement, Optical Drive: paso 4, imagen 3 de 3
    • Using the Phillips size 00 screwdriver, unscrew the 4.7 mm screw that holds the optical drive.
    • Use the opening tool to slide the drive out the side of the laptop to remove it.
Conclusión
Colin Klaes
Miembro Desde 03/21/19
259 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 163
