Saltar al contenido principal
HP Pavilion g7-1365dx Keyboard Replacement
Qué necesitas
  1. HP Pavilion g7-1365dx Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Keyboard Replacement: paso 2, imagen 1 de 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Keyboard Replacement, Service Door: paso 3, imagen 1 de 2 HP Pavilion g7-1365dx Keyboard Replacement, Service Door: paso 3, imagen 2 de 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 HP Pavilion g7-1365dx Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Remove the 4.7 mm screw that secures the keyboard to the computer using the Philips 00 screwdriver.
  5. HP Pavilion g7-1365dx Keyboard Replacement: paso 5, imagen 1 de 1
    • Rest the laptop on its side so the optical drive is pointing up.
    • Insert the hex 2.0 screwdriver into the screw hole that had the 4.7 mm screw, press till the keyboard pops out.
  6. HP Pavilion g7-1365dx Keyboard Replacement: paso 6, imagen 1 de 1
    • Turn the laptop right side up, facing you. Use the opening tool to help pull the keyboard towards you.
  7. HP Pavilion g7-1365dx Keyboard Replacement: paso 7, imagen 1 de 1
    • Unplug the keyboard ribbon cable and remove the keyboard.
Conclusión
jonathan Rodriguez
Miembro Desde 03/26/19
109 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 467
