Saltar al contenido principal
HP Pavilion g7-1365dx Hard Drive Replacement
Qué necesitas
  1. HP Pavilion g7-1365dx Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Hard Drive Replacement: paso 2, imagen 1 de 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Hard Drive Replacement, Service Door: paso 3, imagen 1 de 2 HP Pavilion g7-1365dx Hard Drive Replacement, Service Door: paso 3, imagen 2 de 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 3 HP Pavilion g7-1365dx Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 3 HP Pavilion g7-1365dx Hard Drive Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Disconnect the drive connector cable from the system board by pulling the plastic tab on top of the connector.
    • Use the opening tool to lift the hard drive out.
    • Remove the hard drive.
Conclusión
Derrick Manu
Miembro Desde 03/18/19
245 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 363
