Saltar al contenido principal
HP Pavilion g7-1150us Surface Panel Replacement
Qué necesitas
  1. HP Pavilion g7-1150us Surface Panel Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion g7-1150us Surface Panel Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Surface Panel Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Surface Panel Replacement, Surface Panel: paso 3, imagen 1 de 1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Surface Panel Replacement: paso 4, imagen 1 de 2 HP Pavilion g7-1150us Surface Panel Replacement: paso 4, imagen 2 de 2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Surface Panel Replacement: paso 5, imagen 1 de 1
    • Lift the pried surface panel off of the computer.
Conclusión
Kyle Dinunno
Miembro Desde 03/20/19
377 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 285
