Saltar al contenido principal
HP Pavilion g6-2228tx RAM Replacement
Qué necesitas
  1. HP Pavilion g6-2228tx RAM Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion g6-2228tx RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Push the battery latch to the left to release the battery.
    • Remove the battery from the device.
  2. HP Pavilion g6-2228tx RAM Replacement, Hard Drive: paso 2, imagen 1 de 2 HP Pavilion g6-2228tx RAM Replacement, Hard Drive: paso 2, imagen 2 de 2
    • Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
  3. HP Pavilion g6-2228tx RAM Replacement: paso 3, imagen 1 de 3 HP Pavilion g6-2228tx RAM Replacement: paso 3, imagen 2 de 3 HP Pavilion g6-2228tx RAM Replacement: paso 3, imagen 3 de 3
    • Place your hand on the cover and slide the cover down.
    • Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
  4. HP Pavilion g6-2228tx RAM Replacement: paso 4, imagen 1 de 2 HP Pavilion g6-2228tx RAM Replacement: paso 4, imagen 2 de 2
    • Place one finger on the right side of the hard drive.
    • Push the hard drive to the left and lift the hard drive up to remove it from the device.
  5. HP Pavilion g6-2228tx RAM Replacement: paso 5, imagen 1 de 2 HP Pavilion g6-2228tx RAM Replacement: paso 5, imagen 2 de 2
    • Disconnect the connecting part by pulling the part to the right.
    • Remove the hard drive from the device.
  6. HP Pavilion g6-2228tx RAM Replacement, RAM: paso 6, imagen 1 de 2 HP Pavilion g6-2228tx RAM Replacement, RAM: paso 6, imagen 2 de 2
    • The silver hinges holds the RAM in place.
  7. HP Pavilion g6-2228tx RAM Replacement: paso 7, imagen 1 de 2 HP Pavilion g6-2228tx RAM Replacement: paso 7, imagen 2 de 2
    • Use two fingers to push both silver hinges outward to release the RAM.
    • The released RAM will pop up.
  8. HP Pavilion g6-2228tx RAM Replacement: paso 8, imagen 1 de 1
    • Pull the RAM stick to the left and remove it from the device.
Conclusión
Hai Lin
Miembro Desde 10/19/18
446 Reputación
4 Guías creadas
Equipo
UC Davis, Team S4-G6, Lore Fall 2018 Miembro de UC Davis, Team S4-G6, Lore Fall 2018
UCD-LORE-F18S4G6
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 704
