Introducción
Components below the laptop need to be removed before you can detach the keyboard. This is a guide to remove your laptop's keyboard.
Qué necesitas
Flip the computer so the bottom is facing up with the battery away from you.
Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
Using a PH 00 screwdriver, remove the screw located next to the wireless card.
9 personas más completaron esta guía.
