Saltar al contenido principal
HP Pavilion g4-1117dx Larger Back Panel Replacement
Qué necesitas
  1. HP Pavilion g4-1117dx Larger Back Panel Replacement, Battery: paso 1, imagen 1 de 1
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Larger Back Panel Replacement, L-Shaped Back Panel: paso 3, imagen 1 de 1
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Larger Back Panel Replacement: paso 4, imagen 1 de 1
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Larger Back Panel Replacement, Larger Back Panel: paso 5, imagen 1 de 1
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  5. HP Pavilion g4-1117dx Larger Back Panel Replacement: paso 6, imagen 1 de 1
    • Remove 3 screws located where the battery previously was.
  6. HP Pavilion g4-1117dx Larger Back Panel Replacement: paso 7, imagen 1 de 2 HP Pavilion g4-1117dx Larger Back Panel Replacement: paso 7, imagen 2 de 2
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  7. HP Pavilion g4-1117dx Larger Back Panel Replacement: paso 8, imagen 1 de 1
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  8. HP Pavilion g4-1117dx Larger Back Panel Replacement: paso 9, imagen 1 de 1
    • Unplug wires connecting back panel to keyboard.
Conclusión
Robert Hamilton
Miembro Desde 03/01/18
1,165 Reputación
10 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 384
