Saltar al contenido principal
HP Pavilion dv9000 Wireless Card Replacement
Qué necesitas
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: paso 2, imagen 1 de 2 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: paso 2, imagen 2 de 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: paso 3, imagen 1 de 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: paso 3, imagen 2 de 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: paso 3, imagen 3 de 3
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: paso 4, imagen 1 de 3 HP Pavilion dv9000 Wireless Card Replacement: paso 4, imagen 2 de 3 HP Pavilion dv9000 Wireless Card Replacement: paso 4, imagen 3 de 3
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: paso 5, imagen 1 de 2 HP Pavilion dv9000 Wireless Card Replacement: paso 5, imagen 2 de 2
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
Conclusión
2 personas más completaron esta guía.
Erik Hoffnagle
Miembro Desde 04/11/13
750 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-32, Maness Winter 2014 Miembro de Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 3,935
