Saltar al contenido principal
HP Pavilion dv9000 RAM Replacement
Qué necesitas
  1. HP Pavilion dv9000 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 RAM Replacement, Battery Removal: paso 2, imagen 1 de 2 HP Pavilion dv9000 RAM Replacement, Battery Removal: paso 2, imagen 2 de 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 RAM Replacement, RAM: paso 3, imagen 1 de 3 HP Pavilion dv9000 RAM Replacement, RAM: paso 3, imagen 2 de 3 HP Pavilion dv9000 RAM Replacement, RAM: paso 3, imagen 3 de 3
    • Locate the middle plastic cover on the bottom of the laptop.
    • Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
    • Lift and remove the plastic cover.
  4. HP Pavilion dv9000 RAM Replacement: paso 4, imagen 1 de 3 HP Pavilion dv9000 RAM Replacement: paso 4, imagen 2 de 3 HP Pavilion dv9000 RAM Replacement: paso 4, imagen 3 de 3
    • Locate the RAM card and the metal tabs on either side of it.
    • Press both tabs away from the RAM card to release it. The card should flip up towards you.
    • Carefully lift the RAM card out.
Conclusión
Una persona más ha completado esta guía.
Erik Hoffnagle
Miembro Desde 04/11/13
750 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-32, Maness Winter 2014 Miembro de Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 3,525
