Saltar al contenido principal
HP Pavilion dv7t-7000 Wi-Fi Card Replacement
Qué necesitas
  1. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: paso 2, imagen 1 de 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: paso 3, imagen 1 de 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Back Panel: paso 4, imagen 1 de 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: paso 5, imagen 1 de 2 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: paso 5, imagen 2 de 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Wi-Fi Card: paso 6, imagen 1 de 2 HP Pavilion dv7t-7000 Wi-Fi Card Replacement, Wi-Fi Card: paso 6, imagen 2 de 2
    • Use the flat end of a spudger to pop off the antenna connectors.
  7. HP Pavilion dv7t-7000 Wi-Fi Card Replacement: paso 7, imagen 1 de 3 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: paso 7, imagen 2 de 3 HP Pavilion dv7t-7000 Wi-Fi Card Replacement: paso 7, imagen 3 de 3
    • Remove single Phillips #00 screw.
    • Pull the card out by hand.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 172
