Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
A guide to replace the hard drive on the HP Pavilion dv7t-7000.
Partes
No se especificaron partes.
  1. Turn the computer off and disconnect if from all power sources.
    • Turn the computer off and disconnect if from all power sources.
  2. Slide the battery release switch to the left.
    • Slide the battery release switch to the left.
  3. Hold the release switch all of the way to the left and your other hand to pull the battery out.
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. Unscrew the single Phillips #00 screw.
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. Remove service hatch by sliding away from the computer and lifting up. Remove service hatch by sliding away from the computer and lifting up.
    • Remove service hatch by sliding away from the computer and lifting up.
  6. Remove the two Phillips #00 screws holding in the hard drive.
    • Remove the two Phillips #00 screws holding in the hard drive.
  7. Grab the black tab on the hard drive and pull left and then upwards to remove. Grab the black tab on the hard drive and pull left and then upwards to remove.
    • Grab the black tab on the hard drive and pull left and then upwards to remove.
  8. Remove the four Phillips #00 screws holding the hard drive to its case.
    • Remove the four Phillips #00 screws holding the hard drive to its case.
  9. Slide the casing off of the hard drive. Slide the casing off of the hard drive.
    • Slide the casing off of the hard drive.
  10. Unplug the hard drive from the device.
    • Unplug the hard drive from the device.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 197
