Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
A guide to take off the back panel on an HP Pavilion dv7t-7000.
Partes
No se especificaron partes.
  1. Turn the computer off and disconnect if from all power sources.
    • Turn the computer off and disconnect if from all power sources.
  2. Slide the battery release switch to the left.
    • Slide the battery release switch to the left.
  3. Hold the release switch all of the way to the left and your other hand to pull the battery out.
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. Unscrew the single Phillips #00 screw.
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. Remove service hatch by sliding away from the computer and lifting up. Remove service hatch by sliding away from the computer and lifting up.
    • Remove service hatch by sliding away from the computer and lifting up.
Conclusión
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 294
