Saltar al contenido principal
HP Pavilion dv7-6178us RAM Replacement
  1. HP Pavilion dv7-6178us RAM Replacement, RAM: paso 1, imagen 1 de 2 HP Pavilion dv7-6178us RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us RAM Replacement: paso 2, imagen 1 de 1
    • Locate the RAM and push the two tabs on the sides away from the RAM.
  3. HP Pavilion dv7-6178us RAM Replacement: paso 3, imagen 1 de 1
    • Once the tabs on the sides are released the RAM card will pop out by itself to this angle, as shown in the picture.
  4. HP Pavilion dv7-6178us RAM Replacement: paso 4, imagen 1 de 1
    • Pull the card out of the socket and you have successfully removed one RAM card.
  5. HP Pavilion dv7-6178us RAM Replacement: paso 5, imagen 1 de 2 HP Pavilion dv7-6178us RAM Replacement: paso 5, imagen 2 de 2
    • Steps 2 through 4 can also be done on the second RAM card, located directly below the initial RAM card.
Conclusión
Branden Simas
Miembro Desde 10/20/18
178 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 575
