Introducción
Are you having keyboard malfunctions? You may need to replace your keys. This may happen if you often eat on your personal computer. This common glitch is called "sticky keys". However, it is a simple fix! This guide will walk you through the proper steps to take to access and replace your keys.
Qué necesitas
Remove the key by prying at the top part of the key using the plastic opening tool.
Casi Terminas!
Conclusión
