Saltar al contenido principal
HP Pavilion dv7-6178us Hard Drive Replacement
Qué necesitas
  1. HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us Hard Drive Replacement: paso 2, imagen 1 de 1
    • Now, with the back piece off, you will remove the four screws holding it in place. Use a Phillips head screwdriver.
    • Take note of where you place the screws because you will need them for later.
  3. HP Pavilion dv7-6178us Hard Drive Replacement: paso 3, imagen 1 de 2 HP Pavilion dv7-6178us Hard Drive Replacement: paso 3, imagen 2 de 2
    • Place the old hard drive off to the side (as seen in photo) and carefully remove the SATA cable from laptop.
    • Be careful to not damage the laptop or cable when doing this step. A gentle pull should do the trick.
Conclusión
2 personas más completaron esta guía.
Zach Lunghi
Miembro Desde 10/19/18
148 Reputación
1 Guía escrita
Equipo
Un comentario
This is a really GREAT thing that's being done!
It's high time that consumers fought back and stop letting the TECHNO-OVERLORDS, collectively STRIP us of the right to use the digital tools that we purchase from them.
Walter D Wormack - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 24
Todo El Tiempo: 2,024
