Saltar al contenido principal
HP Pavilion dv7-4285dx Keyboard Replacement
Qué necesitas
  1. HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery release switch to the left. The battery pack will then subsequently release.
  2. HP Pavilion dv7-4285dx Keyboard  Replacement: paso 2, imagen 1 de 1
    • Remove the battery pack from the socket.
  3. HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: paso 3, imagen 1 de 3 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: paso 3, imagen 2 de 3 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: paso 3, imagen 3 de 3
    • Unscrew the 5 black plate screws using a Ph#0 screwdriver.
    • During the removal process, the back plate will retain the 5 back plate screws.
    • Use a metal spudger to carefully remove back plate.
  4. HP Pavilion dv7-4285dx Keyboard  Replacement: paso 4, imagen 1 de 1
    • Unscrew the 7.2mm screws using a Ph#0 screwdriver.
  5. HP Pavilion dv7-4285dx Keyboard  Replacement: paso 5, imagen 1 de 2 HP Pavilion dv7-4285dx Keyboard  Replacement: paso 5, imagen 2 de 2
    • Push the keyboard release switch using the metal spudger.
  6. HP Pavilion dv7-4285dx Keyboard  Replacement: paso 6, imagen 1 de 2 HP Pavilion dv7-4285dx Keyboard  Replacement: paso 6, imagen 2 de 2
    • Lift up keyboard from its resting position.
  7. HP Pavilion dv7-4285dx Keyboard  Replacement: paso 7, imagen 1 de 3 HP Pavilion dv7-4285dx Keyboard  Replacement: paso 7, imagen 2 de 3 HP Pavilion dv7-4285dx Keyboard  Replacement: paso 7, imagen 3 de 3
    • Lift up black tab holding ribbon cable.
    • Remove ribbon cable from motherboard.
  8. HP Pavilion dv7-4285dx Keyboard  Replacement: paso 8, imagen 1 de 1
    • Remove keyboard.
Conclusión
Austin Sandel
Miembro Desde 11/05/18
363 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G2, Baechle Fall 2018 Miembro de IUPUI, Team S1-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G2
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 439
