Saltar al contenido principal
HP Pavilion dv7-3065dx Disk Drive Replacement
Qué necesitas
  1. HP Pavilion dv7-3065dx Disk Drive Replacement, Disk Drive: paso 1, imagen 1 de 2 HP Pavilion dv7-3065dx Disk Drive Replacement, Disk Drive: paso 1, imagen 2 de 2
    • Remove the Battery as a safety precaution
    • There is a latch identified in the picture. By sliding this latch to the left, the battery is released from a lock position.
  2. HP Pavilion dv7-3065dx Disk Drive Replacement: paso 2, imagen 1 de 1
    • Use a Philips screwdriver to unscrew one screw holding the disk drive to the laptop.
    • In the photo there is a covering missing from another piece of the laptop but this will not impact the disk drive.
  3. HP Pavilion dv7-3065dx Disk Drive Replacement: paso 3, imagen 1 de 1
    • Slide (pull) the disk drive out from the laptop and place it off to the side.
    • The disk drive is the silver container as seen in the photo.
Conclusión
Bailey York
Miembro Desde 02/07/17
101 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-5, Wilder Spring 2017 Miembro de Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 737
