Saltar al contenido principal
HP Pavilion dv7-1448dx Battery Replacement
  1. HP Pavilion dv7-1448dx Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx Battery Replacement: paso 2, imagen 1 de 2 HP Pavilion dv7-1448dx Battery Replacement: paso 2, imagen 2 de 2
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx Battery Replacement: paso 3, imagen 1 de 2 HP Pavilion dv7-1448dx Battery Replacement: paso 3, imagen 2 de 2
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
Conclusión
To reinsert a new battery, follow these instructions in reverse order.
Equipo
Baylor, Team 3-5, Whitney Spring 2017 Miembro de Baylor, Team 3-5, Whitney Spring 2017
BU-WHITNEY-S17S3G5
2 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 225
