Saltar al contenido principal
HP Pavilion dv7-1285dx Wifi Card Replacement
Qué necesitas
  1. HP Pavilion dv7-1285dx Wifi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Wifi Card Replacement, Back Plate: paso 2, imagen 1 de 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Wifi Card Replacement: paso 3, imagen 1 de 2 HP Pavilion dv7-1285dx Wifi Card Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx Wifi Card Replacement, Wifi Card: paso 4, imagen 1 de 1
    • Locate the wifi card to the right of the RAM.
  5. HP Pavilion dv7-1285dx Wifi Card Replacement: paso 5, imagen 1 de 1
    • Unplug antenna cables 1 and 2 from their leads.
    • Antenna cable 3 is not used.
  6. HP Pavilion dv7-1285dx Wifi Card Replacement: paso 6, imagen 1 de 1
    • Remove the two Phillips head screws located on the battery compartment side of the wifi card.
  7. HP Pavilion dv7-1285dx Wifi Card Replacement: paso 7, imagen 1 de 1
    • Gently lift the wifi card up to a 45 degree angle from the side with screws.
  8. HP Pavilion dv7-1285dx Wifi Card Replacement: paso 8, imagen 1 de 2 HP Pavilion dv7-1285dx Wifi Card Replacement: paso 8, imagen 2 de 2
    • Unplug the wifi card.
  9. HP Pavilion dv7-1285dx Wifi Card Replacement: paso 9, imagen 1 de 1
    • These next steps are for installing your replacement wifi card. These steps are very important to ensure that you do not damage your device.
    • Fully insert the replacement wifi card at a 45 degree angle, ensuring that the notch on the card lines up with the peg on the plug.
  10. HP Pavilion dv7-1285dx Wifi Card Replacement: paso 10, imagen 1 de 1
    • Gently push the wifi card down until the screws can be replaced.
  11. HP Pavilion dv7-1285dx Wifi Card Replacement: paso 11, imagen 1 de 1
    • Connect the antenna cable 1 with lead 1 and connect antenna cable 2 with lead 2.
    • Wire 1 needs to be connected to lead 1 and wire 2 needs to be connected to lead 2.
    • Wire 3 and lead 3 are not used.
Conclusión
2 personas más completaron esta guía.
Anmol Mathur
Miembro Desde 04/14/14
291 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 12-34, Maness Spring 2014 Miembro de Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 2,123
