Introducción
Be sure to back-up your device prior to replacing your hard drive.
Qué necesitas
Ensure the device is powered down and unplugged.
Turn the device upside down with the battery compartment facing you.
Slide the black slider to the right and lift the battery out of its compartment.
Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
Rotate the device 180 degrees.
Locate the 2 black Phillips PM2.5×7.0 screws on the right side of the hard drive case and unscrew them.
3 personas más completaron esta guía.
