Saltar al contenido principal
HP Pavilion dv7-1285dx Back Plate Replacement
Qué necesitas
  1. HP Pavilion dv7-1285dx Back Plate Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Back Plate Replacement, Back Plate: paso 2, imagen 1 de 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Back Plate Replacement: paso 3, imagen 1 de 2 HP Pavilion dv7-1285dx Back Plate Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
Conclusión
Chris Apple
Miembro Desde 04/14/14
239 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 12-34, Maness Spring 2014 Miembro de Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,513
