Saltar al contenido principal
HP Pavilion dv6t-1200 Disk Tray Replacement
Qué necesitas
  1. HP Pavilion dv6t-1200 Disk Tray Replacement, Disk Tray: paso 1, imagen 1 de 2 HP Pavilion dv6t-1200 Disk Tray Replacement, Disk Tray: paso 1, imagen 2 de 2
    • Locate the small hole on the right side of the disk tray next to the button.
  2. HP Pavilion dv6t-1200 Disk Tray Replacement: paso 2, imagen 1 de 2 HP Pavilion dv6t-1200 Disk Tray Replacement: paso 2, imagen 2 de 2
    • Extend the paper clip into a straight line and insert it into the disk tray hole located next to the release button.
    • When the disk tray is removed, make sure to clean the general area with canned air.
  3. HP Pavilion dv6t-1200 Disk Tray Replacement: paso 3, imagen 1 de 1
    • Flip the laptop to the other side and remove the four screws on the bottom of the disk tray using a Phillips #0 screwdriver.
  4. HP Pavilion dv6t-1200 Disk Tray Replacement: paso 4, imagen 1 de 2 HP Pavilion dv6t-1200 Disk Tray Replacement: paso 4, imagen 2 de 2
    • Remove the metal plate and locate the bottom right tool for the disk tray.
  5. HP Pavilion dv6t-1200 Disk Tray Replacement: paso 5, imagen 1 de 2 HP Pavilion dv6t-1200 Disk Tray Replacement: paso 5, imagen 2 de 2
    • Replace the motor piece that is being held and reclose the device.
  6. HP Pavilion dv6t-1200 Disk Tray Replacement: paso 6, imagen 1 de 2 HP Pavilion dv6t-1200 Disk Tray Replacement: paso 6, imagen 2 de 2
    • After replacing the motor and the placing the metal tray apply a good amount of WD40.
    • Once all completed the disk tray should be working smoothly.
Conclusión
Una persona más ha completado esta guía.
Daniel Pelayo
Miembro Desde 10/05/21
210 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 268
