Saltar al contenido principal
HP Pavilion dv6500 Touchpad Replacement
Qué necesitas
  1. HP Pavilion dv6500 Touchpad Replacement, Battery: paso 1, imagen 1 de 1
    • Flip computer face down.
  2. HP Pavilion dv6500 Touchpad Replacement: paso 2, imagen 1 de 1
    • Remove the battery by sliding the button to the side.
    • Be careful if the battery is leaking or appears punctured in anyway. Battery acid is harmful and may cause burns.
  3. HP Pavilion dv6500 Touchpad Replacement, Back Panel: paso 3, imagen 1 de 1
    • Remove fifteen 7.0mm PH0 screws.
    • Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
  4. HP Pavilion dv6500 Touchpad Replacement, Keyboard: paso 4, imagen 1 de 2 HP Pavilion dv6500 Touchpad Replacement, Keyboard: paso 4, imagen 2 de 2
    • Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
  5. HP Pavilion dv6500 Touchpad Replacement: paso 5, imagen 1 de 1
    • Gently pull on the 2 ribbon cables until they detach from the computer.
    • Unplug cables connecting the top keyboard assembly and computer body.
    • Be careful not to rip the speaker cables.
  6. HP Pavilion dv6500 Touchpad Replacement: paso 6, imagen 1 de 1
    • The top of the keyboard should be exposed enough to unclip and slide the keyboard out from the clips near the trackpad on the laptop.
    • Gently pull the flat black cable toward the monitor to remove the cable from the motherboard, freeing the keyboard.
    • Be careful not to pull too hard and damage the black cable.
  7. HP Pavilion dv6500 Touchpad Replacement: paso 7, imagen 1 de 1
    • Insert new keyboard by sliding it into place of original keyboard and clipping into place near top of trackpad.
  8. HP Pavilion dv6500 Touchpad Replacement, Touchpad: paso 8, imagen 1 de 1
    • Using the size 5.0mm hex tool, unscrew the 2 brass screws located near the RAM cards under the laptop.
  9. HP Pavilion dv6500 Touchpad Replacement: paso 9, imagen 1 de 1
    • Remove the 4 7mm screws holding the metal plate to the rest of the laptop.
    • Lift the metal plate off the laptop and turn over to reveal the underside of the mouse pad
  10. HP Pavilion dv6500 Touchpad Replacement: paso 10, imagen 1 de 3 HP Pavilion dv6500 Touchpad Replacement: paso 10, imagen 2 de 3 HP Pavilion dv6500 Touchpad Replacement: paso 10, imagen 3 de 3
    • Flip the metal plate over to expose the screws holding the keypad in place.
    • Remove the 6 7.0mm screws holding the mousepad in place.
  11. HP Pavilion dv6500 Touchpad Replacement: paso 11, imagen 1 de 1
    • Remove the 4 7mm screws, 2 on either side of the mouse pad.
Conclusión
Andrew
Miembro Desde 10/23/16
392 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-6, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-6, Catania Fall 2016
UMASSD-CATANIA-F16S1G6
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,061
