Saltar al contenido principal
HP Pavilion dv6000 Speaker Bar Replacement
Qué necesitas
  1. HP Pavilion dv6000 Speaker Bar Replacement, Speaker Bar: paso 1, imagen 1 de 1
    • Make sure the laptop lid is closed, turn it over and remove the battery by moving the switch right to left.
    • there are three philips screws located on the surface where the writing is. remove those three screws.
  2. HP Pavilion dv6000 Speaker Bar Replacement: paso 2, imagen 1 de 1
    • turn the laptop right side up. Between the cover and case on the top right of the laptop and using a plastic sludger or a finger lift gently on the speaker cover as to disengage the clips.
    • Be sure not to pull hard or you may damage the ribbon cables.
    • From the side closest to the screen turn the cover towards yourself.
  3. HP Pavilion dv6000 Speaker Bar Replacement: paso 3, imagen 1 de 1
    • there is one connector from the speaker bar to a control board. Gently remove the cable.
    • There are two more screws attaching the speaker bar to the cover, remove these and take the speaker bar out.
  4. HP Pavilion dv6000 Speaker Bar Replacement: paso 4, imagen 1 de 1
    • you are now ready to replace or repair the speaker bar. I recomend purchasing a new one, they range anywhere from 5-15 dollars online.
Conclusión
5 personas más completaron esta guía.
Joba Fett
Miembro Desde 04/11/14
227 Reputación
1 Guía escrita
2 comentarios
how to fix speaker from board
kingsley Osunkwo - Contestar
Grazie siete bravissimi . Ce ne fossero persone come voi che altruisticamente mettono a disposizione la loro esperienza di riparazioni per gli altri!
Fernando Mancini
fernando mancini - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 3,333
