Saltar al contenido principal
HP Pavilion dv6-6117dx RAM Replacement
Qué necesitas
  1. HP Pavilion dv6-6117dx RAM Replacement, RAM: paso 1, imagen 1 de 2 HP Pavilion dv6-6117dx RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx RAM Replacement: paso 2, imagen 1 de 2 HP Pavilion dv6-6117dx RAM Replacement: paso 2, imagen 2 de 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx RAM Replacement: paso 3, imagen 1 de 3 HP Pavilion dv6-6117dx RAM Replacement: paso 3, imagen 2 de 3 HP Pavilion dv6-6117dx RAM Replacement: paso 3, imagen 3 de 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx RAM Replacement: paso 4, imagen 1 de 2 HP Pavilion dv6-6117dx RAM Replacement: paso 4, imagen 2 de 2
    • Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
  5. HP Pavilion dv6-6117dx RAM Replacement: paso 5, imagen 1 de 2 HP Pavilion dv6-6117dx RAM Replacement: paso 5, imagen 2 de 2
    • Always handle RAM by the edges to avoid damaging the part.
    • Remove the RAM by grabbing it by the sides and pulling out at a 45º angle.
    • When inserting the new stick of RAM, you should insert it at this same angle.
Conclusión
Joshua Holme
Miembro Desde 03/19/18
765 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 682
