Saltar al contenido principal
HP Pavilion dv6-6117dx Optical Drive Replacement
Qué necesitas
  1. HP Pavilion dv6-6117dx Optical Drive Replacement, Optical Drive: paso 1, imagen 1 de 2 HP Pavilion dv6-6117dx Optical Drive Replacement, Optical Drive: paso 1, imagen 2 de 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Optical Drive Replacement: paso 2, imagen 1 de 2 HP Pavilion dv6-6117dx Optical Drive Replacement: paso 2, imagen 2 de 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Optical Drive Replacement: paso 3, imagen 1 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: paso 3, imagen 2 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: paso 3, imagen 3 de 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Optical Drive Replacement: paso 4, imagen 1 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: paso 4, imagen 2 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #0 screw driver, remove the single 4mm screw holding the optical drive in place
  5. HP Pavilion dv6-6117dx Optical Drive Replacement: paso 5, imagen 1 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: paso 5, imagen 2 de 3 HP Pavilion dv6-6117dx Optical Drive Replacement: paso 5, imagen 3 de 3
    • Using a plastic spudger, push the optical drive out toward the left of the device
Conclusión
Joshua Holme
Miembro Desde 03/19/18
765 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 306
