Saltar al contenido principal
HP Pavilion dv6-1245dx RAM Replacement
Qué necesitas
  1. HP Pavilion dv6-1245dx RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Shut down the computer and unplug it from the outlet.
    • All screws removed in this guide will require a Phillips #00 screwdriver.
  2. HP Pavilion dv6-1245dx RAM Replacement: paso 2, imagen 1 de 1
    • Turn the computer upside down.
  3. HP Pavilion dv6-1245dx RAM Replacement: paso 3, imagen 1 de 1
    • Loosen the three screws from the memory module compartment cover
    • Screws will not come all the way out.
  4. HP Pavilion dv6-1245dx RAM Replacement: paso 4, imagen 1 de 1
    • Remove the memory module compartment cover.
  5. HP Pavilion dv6-1245dx RAM Replacement: paso 5, imagen 1 de 3 HP Pavilion dv6-1245dx RAM Replacement: paso 5, imagen 2 de 3 HP Pavilion dv6-1245dx RAM Replacement: paso 5, imagen 3 de 3
    • Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
    • Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
    • If you are replacing both memory cards, repeat this step with the bottom memory card.
  6. HP Pavilion dv6-1245dx RAM Replacement: paso 6, imagen 1 de 1
    • To replace the memory card, insert the card at a 45-degree angle, then push into slot.
    • Push down gently so the silver retaining tabs click back into place.
    • If you are replacing both memory cards, replace the bottom card (closest to the system board) first.
Conclusión
4 personas más completaron esta guía.
Jaime
Miembro Desde 01/23/14
562 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 2,375
