Saltar al contenido principal
HP Pavilion dv5000 Wifi Card
Qué necesitas
  1. HP Pavilion dv5000 Wifi Card, Battery: paso 1, imagen 1 de 1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Wifi Card, RAM Cover: paso 2, imagen 1 de 3 HP Pavilion dv5000 Wifi Card, RAM Cover: paso 2, imagen 2 de 3 HP Pavilion dv5000 Wifi Card, RAM Cover: paso 2, imagen 3 de 3
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 Wifi Card, Wifi Card: paso 3, imagen 1 de 2 HP Pavilion dv5000 Wifi Card, Wifi Card: paso 3, imagen 2 de 2
    • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
  4. HP Pavilion dv5000 Wifi Card: paso 4, imagen 1 de 2 HP Pavilion dv5000 Wifi Card: paso 4, imagen 2 de 2
    • Remove the two 6.0mm Phillips screws from the wifi card.
    • Remove the wifi card.
Conclusión
Sam Kaplan
Miembro Desde 10/11/10
253 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 21-34, Regan Fall 2010 Miembro de Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 7,025
