Saltar al contenido principal
HP Pavilion dv4000 Keyboard Replacement
Qué necesitas
  1. HP Pavilion dv4000 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Keyboard Replacement: paso 3, imagen 1 de 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Have your device open in front of you for easy access to the keyboard.
  5. HP Pavilion dv4000 Keyboard Replacement: paso 5, imagen 1 de 1
    • Using a metal spudger, pry up on the plastic piece above the keyboard containing the power button.
    • Be careful not to damage any components with the tool while prying.
  6. HP Pavilion dv4000 Keyboard Replacement: paso 6, imagen 1 de 1
    • Lift the plastic piece up.
    • When lifting this piece, be careful not to damage the ribbon strip connected to it.
  7. HP Pavilion dv4000 Keyboard Replacement: paso 7, imagen 1 de 3 HP Pavilion dv4000 Keyboard Replacement: paso 7, imagen 2 de 3 HP Pavilion dv4000 Keyboard Replacement: paso 7, imagen 3 de 3
    • Place the plastic piece on the keyboard so the ribbon strip is easily accessible.
    • Carefully disconnect the ribbon strip from the keyboard by pressing on the tabs at the edges.
    • Remove plastic piece and set aside.
  8. HP Pavilion dv4000 Keyboard Replacement: paso 8, imagen 1 de 1
    • Locate the four 2x2 mm screws that hold the keyboard in place.
  9. HP Pavilion dv4000 Keyboard Replacement: paso 9, imagen 1 de 1
    • Unscrew the four 2x2 mm screws with a #00 Phillips screwdriver.
  10. HP Pavilion dv4000 Keyboard Replacement: paso 10, imagen 1 de 2 HP Pavilion dv4000 Keyboard Replacement: paso 10, imagen 2 de 2
    • Lift the keyboard up.
    • When lifting the keyboard, be sure not to damage the ribbon strip that is connected to it.
  11. HP Pavilion dv4000 Keyboard Replacement: paso 11, imagen 1 de 1
    • Locate where the ribbon strip is connected to the motherboard.
  12. HP Pavilion dv4000 Keyboard Replacement: paso 12, imagen 1 de 2 HP Pavilion dv4000 Keyboard Replacement: paso 12, imagen 2 de 2
    • Pry at the edges of the plastic clip holding the ribbon cable to the motherboard.
    • Be careful during this step as these clips are very easy to break.
  13. HP Pavilion dv4000 Keyboard Replacement: paso 13, imagen 1 de 3 HP Pavilion dv4000 Keyboard Replacement: paso 13, imagen 2 de 3 HP Pavilion dv4000 Keyboard Replacement: paso 13, imagen 3 de 3
    • Remove the keyboard.
Conclusión
Una persona más ha completado esta guía.
Nick LaMarche
Miembro Desde 10/18/16
373 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-2, Catania Fall 2016 Miembro de UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 907
