Saltar al contenido principal
HP Pavilion dv4000 Heat Sink Replacement
Qué necesitas
  1. HP Pavilion dv4000 Heat Sink Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Heat Sink Replacement: paso 2, imagen 1 de 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Heat Sink Replacement: paso 3, imagen 1 de 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Heat Sink Replacement, Heat Sink: paso 4, imagen 1 de 1
    • Position laptop with heat sink compartment facing you.
    • Locate the one 2x5 mm Torx screw.
  5. HP Pavilion dv4000 Heat Sink Replacement: paso 5, imagen 1 de 1
    • Remove the one 2x5 mm Torx screw securing the thermal cover with a #6 Torx screwdriver.
  6. HP Pavilion dv4000 Heat Sink Replacement: paso 6, imagen 1 de 2 HP Pavilion dv4000 Heat Sink Replacement: paso 6, imagen 2 de 2
    • Lift thermal cover to reveal heat sink.
    • Remove and set aside thermal cover.
  7. HP Pavilion dv4000 Heat Sink Replacement: paso 7, imagen 1 de 2 HP Pavilion dv4000 Heat Sink Replacement: paso 7, imagen 2 de 2
    • Locate the four screws on each corner of heat sink.
    • Unscrew the four 2x12 mm screws with a #00 Phillips screwdriver.
  8. HP Pavilion dv4000 Heat Sink Replacement: paso 8, imagen 1 de 2 HP Pavilion dv4000 Heat Sink Replacement: paso 8, imagen 2 de 2
    • Grab sides of heat sink and carefully lift from compartment.
    • Due to adhesive bonding of heat sink to base, wiggling it side to side before lifting might help removal process.
  9. HP Pavilion dv4000 Heat Sink Replacement: paso 9, imagen 1 de 1
    • To reapply thermal paste, check out iFixit's guide here.
Conclusión
Equipo
UMass Dartmouth, Team 4-2, Catania Fall 2016 Miembro de UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 580
