Saltar al contenido principal
HP Pavilion dv4000 RAM Replacement
Qué necesitas
  1. HP Pavilion dv4000  RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000  RAM Replacement: paso 2, imagen 1 de 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000  RAM Replacement: paso 3, imagen 1 de 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000  RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Orient the laptop with the memory cover towards you.
  5. HP Pavilion dv4000  RAM Replacement: paso 5, imagen 1 de 2 HP Pavilion dv4000  RAM Replacement: paso 5, imagen 2 de 2
    • Unscrew the three 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000  RAM Replacement: paso 6, imagen 1 de 1
    • Remove the memory cover.
  7. HP Pavilion dv4000  RAM Replacement: paso 7, imagen 1 de 1
    • Pull the two tabs on both sides of the memory stick to release it.
    • The memory should pop up on its own with very little force applied to the tabs.
  8. HP Pavilion dv4000  RAM Replacement: paso 8, imagen 1 de 2 HP Pavilion dv4000  RAM Replacement: paso 8, imagen 2 de 2
    • Grab the memory stick from the sides with your fingers and set aside.
Conclusión
2 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 4-2, Catania Fall 2016 Miembro de UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Miembros
6 Guías creadas
Un comentario
Hi, how much ram does this laptop support
Sébastien Grant - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 1,148
