Saltar al contenido principal
HP Pavilion dv2913cl WiFi receiver Replacement
Qué necesitas
  1. HP Pavilion dv2913cl WiFi receiver Replacement, WiFi receiver: paso 1, imagen 1 de 1
    • Begin by locating the smallest panel with one screw attaching it to the laptop computer.
  2. HP Pavilion dv2913cl WiFi receiver Replacement: paso 2, imagen 1 de 1
    • Remove the one screw holding the panel down, and the WiFi receiver will be revealed.
  3. HP Pavilion dv2913cl WiFi receiver Replacement: paso 3, imagen 1 de 1
    • Remove the two screws that hold down the receiver.
    • Gently slide the chip out of the socket.
  4. HP Pavilion dv2913cl WiFi receiver Replacement: paso 4, imagen 1 de 2 HP Pavilion dv2913cl WiFi receiver Replacement: paso 4, imagen 2 de 2
    • Remove the two wires labelled AUX and MAIN from the chip.
    • Remember where these were attached previously as it is important for proper functionality after the replacement.
Conclusión
Adam Braga
Miembro Desde 10/24/16
230 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 123
